drawQuery performance...
Ryan, Adam
ARyan at CO.LINN.OR.US
Wed May 4 11:46:43 EDT 2005
Actually your subsequent draw commands may still need to be drawQuery calls
if I remember correctly:
- queryByAttributes
- saveQuery
- drawQuery
- loadQuery
- drawQuery
Adam
> -----Original Message-----
> From: Paul james [mailto:pauljame at GMAIL.COM]
> Sent: Wednesday, May 04, 2005 8:27 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] drawQuery performance...
> Thank you Ryan... That´s it !
> So, I the steps are:
> - queryByAttributes
> - saveQuery
> - drawQuery
> - loadQuery
> - drawMap
> thx
> On 5/4/05, Ryan, Adam <ARyan at co.linn.or.us> wrote:
> > Paul,
> > If I understand correctly, you have a query result that you want to
> > persist in subsequent map.draw() calls. Try using
> map.saveQuery and
> > loadQuery. You would save to a temporary file after your
> > queryByAtributes and then load prior to each map.draw().
> Is that what
> > you're looking for?
> > Adam
> > > Sent: Wednesday, May 04, 2005 5:50 AM
> > > Anyone could tell me, If I´m doing the right thing?
> > > If I need execute drawQuery(so slow) for each iteration with map
> > > (to keep path selected) ?
> > > thx
> > > ----- Original Message -----
> > > From: "Paul james" <pauljame at GMAIL.COM>
> > > To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> > > Sent: Tuesday, May 03, 2005 8:47 PM
> > > Subject: [UMN_MAPSERVER-USERS] drawQuery performance...
> > > In my project, I build a path with queryByAtributes(about
> 300 lines
> > > in result), and after I draw it with drawQuery... But
> this function
> > > is a bit slow... And I must keep this path selected, so I do the
> > > same process for each click in on map (zoom, pan...) . Is
> this the
> > > best way to do it?
> > > Thank you...
