ogrinfo show x y columns as strings
Richard Duivenvoorde
rdmailings at DUIF.NET
Fri May 6 08:42:53 EDT 2005
Hi list,
I have the following txt file that I want to use as a virtual datasource:
text,x,y
test,10,10
test2,11,11
Using a ODBC connection in Windows everything works fine:
ogrinfo ODBC:puntenlaagdsn testpoints.txt
INFO: Open of `ODBC:puntenlaagdsn'
using driver `ODBC' successful.
Layer name: testpoints.txt
Geometry: Unknown (any)
Feature Count: 2
Layer SRS WKT:
(unknown)
text: String (255.0)
x: Integer (10.0)
y: Integer (10.0)
OGRFeature(testpoints.txt):0
text (String) = test
x (Integer) = 10
y (Integer) = 10
OGRFeature(testpoints.txt):1
text (String) = test2
x (Integer) = 11
y (Integer) = 11
But putting everything to linux fails, because ogr(info) (with exactly
the same txt file) reports the x y columns as strings, giving a
featurecount of zero => no features on the map :-(
ogrinfo -ro -al ODBC:@puntenlaagdsn testpoints.txt
INFO: Open of `ODBC:@puntenlaagdsn'
Feature Count: 0
Layer SRS WKT:
(unknown)
x: String (255.0)
y: String (255.0)
Does anybody knows what's the problem?
Is it an odbc problem?
Who is responsible for 'typing' the columns in the txt file?
TIA
Richard
