Problem using Gdal-1.2.6
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri May 6 10:35:02 EDT 2005
On 5/6/05, Johan Hallgren <johan.e.hallgren at wmdata.se> wrote:
> I have installed MapServer 4.6.0-beta1 and now I will add tiff as
> supported input format. I downloaded Gdal-1.2.6 and compiled it (the dll
> and lib was created).
> I uncommented the GDAL options in nmake.opt
> GDAL=-DUSE_GDAL
> GDAL_DIR=C:/SE/GMS/ms/gdal-1.2.6
> Then I buildt the mapserver with:
> nmake /f makefile.vc
Johan,
I don't believe that the object code depends on nmake.opt, so
after changing the configuration in nmake.opt you should generally
do "nmake /f makefile.vc clean" before building the software
again.
The version info from mapserv.exe indicates that GDAL is not
yet enabled.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
