mapserver and postgis
Didrik Pinte
dpinte at ITAE.BE
Sun May 8 17:10:53 EDT 2005
Message also posted to the Debian-GIS mailing list
I'm running the mapserver Sarge package with the latest Postgis package
from Debian-GIS.
I'm having problem using booleans as EXPRESSION in my .map file.
Mapserver does not seem to succeed in the expression evaluation. I do
not see any point when using EXPRESSION.
Here is the mapserver class :
CLASS
NAME "test"
EXPRESSION ([moved] = 't')
COLOR 255 0 0
OUTLINECOLOR 255 0 0
SIZE 10
SYMBOL "circle"
END
And here is the table definition :
CREATE TABLE mapping
id varchar(50) NOT NULL,
moved bool DEFAULT false,
cartopoint geometry,
CONSTRAINT id PRIMARY KEY (id),
CONSTRAINT enforce_dims_cartopoint CHECK (ndims(cartopoint) = 2),
CONSTRAINT enforce_geotype_cartopoint CHECK (geometrytype(cartopoint)
= 'POINT'::text OR cartopoint IS NULL),
CONSTRAINT enforce_srid_cartopoint CHECK (srid(cartopoint) = 4326)
How can I make that work ? I tried to use the text(bool) function inside
Postgres and that works perfectly well :
select text(moved) from tblgeomapping where text(moved)='t';
Any help is welcome.
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050508/836e8e8b/attachment.bin
