Does map Lab Maplab 2.2 and SDE
    Zak James
    zak4ms at GMAIL.COM
    Mon May  9 07:11:05 PDT 2005
Hi Mike,
Unfortunately, we don't have an SDE license so we can't test this, but
SDE connections should work fine from maplab assuming your mapserver
has support compiled in. You will have to look at the Mapserver
documentation and user-list archives for details on what is required
in an SDE layer.
Also, Jeff can better comment on this, but I don't think ms4w includes
SDE support so you may have to create your own binaries to handle
this.
zak
On 4/26/05, Micallef, Michael (MTO) <Michael.Micallef at mto.gov.on.ca> wrote:
> Does maplab 2.2 support SDE as included in the maplab_ms4w-2.2 install?
> If so, what does the layer reference look like?
> What all is required in adding an SDE layer to a map file?
> I have tried adding an SDE layer several times.  I get an error message in
> Map Browser that SDE is not supported?
> Mike Micallef
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
More information about the MapServer-users
