PostGIS pre-instalation considerations (was MyGIS and WFS)
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Tue May 10 03:32:55 EDT 2005
Hi Stefanie,
there are probably some thoughts in the following article:
http://www.greenleaftech.net/articles/msaccesspostgres/document_view
Will the data providers have access to the main database? Then you could use ODBC and use Access as the frontend to the PostgreSQL database to get them to fill the database.
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Stefanie Weykam <sweykam at TELELINE.ES> 05/10/05 09:27am >>>
Thanks, Frank, Bart and Arnulf!
Sounds convincing, I think I will give PostGIS a try.
But - how am I going to explain this to the data providers?! Are there
possibilities to build a bridge between Access and PostgreSQL?
I am afraid, the workload of putting it all together has to be done by many
volunteers (who are not necessarily used to work with relational databases)..
So we thought it was a good idea to have Access in between. Additionally,
the data will also be updated quite frequently.
Any suggestion on how to make things easy for these people (without doing it
all myself for the next few years)??
Perhaps somebody on this list has solved a similar situation? Should be
quite common, I guess.
Stefanie
