Help needed with using .tab files with MapServer
Beales, Joe
Joe.Beales at NORTECHONLINE.CO.UK
Wed May 11 06:41:14 EDT 2005
I'm new to MapServer and I'm having problems in producing a map from
Mapinfo files.
I've got Mapserver 4.5 installed (with ogr support) on apache 2 under
Windows XP Pro. (I've downloaded some tutorials and got them producing
the correct results.)
I've searched the mail list archive and seen some people have had the
same problem but I can't find a definitive answer.
I've used ogrinfo to try and get the correct extent and units.
Below is the Map file I'm using, I am missing something?
I've tried various projections but they don't seem to make a difference.
I've also tried referencing a non-existent .TAB file in the CONNECTION
parameter and don't receive any errors is that normal?
All I get is a blank gif.
MAP
DEBUG ON
NAME "Testing"
EXTENT 57.308593 -20.525013 57.806386 -19.981773
UNITS DD
SHAPEPATH "C:/Program Files/Apache Group/Apache/htdocs/maur/"
IMAGETYPE PNG
IMAGECOLOR 255 255 200
STATUS ON
SIZE 400 400
PROJECTION
#"init=epsg:4326"
"proj=latlong"
"ellps=WGS84"
END
WEB
LOG "C:\mapserv_err.txt"
TEMPLATE "printable.html"
IMAGEPATH "C:/Program Files/Apache Group/Apache2/htdocs/tmp/"
IMAGEURL "/tmp/"
END
LAYER
NAME "Districts"
DEBUG ON
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "C:/Program Files/Apache
Group/Apache2/htdocs/maur/District.TAB"
#DATA "District"
STATUS ON
PROJECTION
#"init=epsg:4326"
"proj=latlong"
"ellps=WGS84"
END
#STYLEITEM "AUTO"
CLASS
OUTLINECOLOR 0 0 0
COLOR 128 128 128
END
END
END
Part Results from ogrinfo:
Layer name: District
Geometry: Polygon
Feature Count: 9
Extent: (57.308593, -20.525013) - (57.806386, -19.981773)
Layer SRS WKT:
GEOGCS["unnamed",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563],
TOWGS84[0,0,0,0,0,0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
Also can anyone point me in the direction of any online resources
intended for peole just getting started with MapServer?
Regards,
Joe Beales.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050511/b08a8638/attachment.html
