Upper/lower case mismatch for PostGIS layers
Daniel
daniel.faivre at CAMPTOCAMP.COM
Wed May 11 10:51:50 EDT 2005
Hello,
I encounter a problem with a PostGIS layer defined with:
DATA "geom from user_FT000001.annuaire"
Mapserver send the request to PostGIS with the schema name in lowercase
(user_ft000001).
But I need to have it in uppercase to comply with the externally defined
database structure ...
Is there a way to have this working without writing a full "select from"
clause ?
Daniel FAIVRE
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050511/371adf96/daniel.faivre.vcf
