Projection Problem
William Hamouz
william.hamouz at PHOENIX.GOV
Wed May 11 19:29:02 EDT 2005
Hi, I am new to projections in mapserver and a seem to have something that
is not working right and I am not sure why. I have striped my example down
to a simple mapfile that has two layers in it. The ogrinfo for the
hospitals layer, which is in a shape file is as follows:
INFO: Open of `c:\geodata\hospitals.shp'
using driver `ESRI Shapefile' successful.
Layer name: hospitals
Geometry: Point
Feature Count: 24
Extent: (561477.687637, 835697.374886) - (729085.875185, 970068.499747)
Layer SRS WKT:
PROJCS["NAD_1983_HARN_StatePlane_Arizona_Central_FIPS_0202_IntlFeet",
GEOGCS["GCS_North_American_1983_HARN",
DATUM["NAD83_High_Accuracy_Regional_Network",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",700000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-111.9166666666667],
PARAMETER["Scale_Factor",0.9999],
PARAMETER["Latitude_Of_Origin",31.0],
UNIT["Foot",0.3048]]
OBJECTID: Integer (10.0)
AREA: Real (19.8)
PERIMETER: Real (19.8)
HOSP83_: Integer (10.0)
HOSP83_ID: Integer (10.0)
TYPE: String (11.0)
ADDRESS: String (30.0)
CITY: String (30.0)
PHONE: String (8.0)
PRJ_NAME: String (120.0)
PRJ_NOTES: String (200.0)
DQ_NOTES: String (80.0)
POLYGONID: Integer (10.0)
SCALE: Real (19.8)
ANGLE: Integer (10.0)
The second layer is a virtual spatial data layer populated from an access
data base. The defintion of the incidents.ovf file is as follows:
<OGRVRTDataSource>
<OGRVRTLayer name="Incidents">
<SrcDataSource>ODBC:UNITSTATUS</SrcDataSource>
<SrcLayer>Incidents</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="Lat"
y="Long"/>
</OGRVRTLayer>
</OGRVRTDataSource>
and the orginfo for the incidents layer is as follows:
Had to open data source read-only.
INFO: Open of `c:\firewire\common\pfdmapcontrol\incidents.ovf'
using driver `VRT' successful.
Layer name: Incidents
Geometry: Point
Feature Count: 23
Extent: (33.233066, -112.296726) - (33.643355, -111.835448)
Layer SRS WKT:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4326"]]
Disp_Type: String (50.0)
Run_no: String (50.0)
Address: String (90.0)
Add_Info: String (50.0)
Nature: String (50.0)
Nature_Disc: String (50.0)
Resp_Type: String (50.0)
Supp_Txt: String (150.0)
Units: String (0.0)
Time: String (19.0)
Date: String (19.0)
X_Streets: String (125.0)
Lat: String (50.0)
Long: String (50.0)
Inc_Type: String (50.0)
Alarm_Lvl: String (50.0)
Channel: String (50.0)
The map that I am trying to display uses the following mapfile:
MAP
NAME PFD
STATUS ON
SIZE 800 500
IMAGETYPE PNG
IMAGECOLOR 240 240 240
SHAPEPATH "C:\GeoData"
FONTSET "C:\FireWire\Common\PFDMAPControl\fonts.list"
EXTENT 576763.692274 832325 697309.177972 1064098
UNITS FEET
WEB
TEMPLATE "PFDMAPImg.html"
IMAGEPATH "C:\FireWire\Images\MapFiles\"
IMAGEURL "/Images/MapFiles/"
END
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
PROJECTION
proj=tmerc
lat_0=31.000000000
lon_0=-111.916666667
x_0=700000
y_0=0.0
k=0.999900
ellps=GRS80
datum=NAD83
to_meter=0.3048006096
no_defs
END
LAYER
NAME "hospitals"
TYPE POINT
STATUS ON
DATA "hospitals"
CLASS
NAME "hospitals"
COLOR 0 0 255
SIZE 14
SYMBOL 'circle'
END
END
LAYER
NAME "incidents"
TYPE POINT
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "incidents.ovf"
DATA "incidents"
PROJECTION
proj=latlong
ellps=GRS80
datum=WGS84
END
CLASS
NAME "incidents"
COLOR 255 0 0
SIZE 14
SYMBOL 'circle'
END
END
END
END
Basically what happens is I do not believe the incidents layer is
projecting correctly because it does not end up in the same general
vacinity with the hospitals layer. To the best of my limited knowledge, I
think I have all the files configured correctly. I know that I am getting
the incident data back becuase it renders, just not in the write place.
Thank You in advance for any help.
Sincerely,
Will Hamouz
Phoenix Fire Department
