queryByAttribute problem
Troy R. Johnson
Troy.Johnson at SDL.USU.EDU
Thu May 12 18:02:58 EDT 2005
Hi all, question:
I have queryByAttribute partially working, but have run into a problem:
I am querying the state boundary shape file as provided in the mapscript
example files (statesp020). For some reason when I query on the name of
a state, I only get valid results when the state has a single entry in
the shape file. For example Idaho, Utah, New Mexico work fine, but
Florida, Alaska don't.
Here is the PHP code I'm using:
//$search_term = "Idaho";
$search_term = "Florida";
$myLayer = $map->getLayerByName("US state boundaries");
$myLayer->queryByAttributes('STATE', '/'.$search_term.'/', MS_MULTIPLE);
$numberofresults = $myLayer->getNumResults();
Like I mentioned above, Idaho works, $numberofresults is equal to 1. For Florida
$numberofresulsts is equal to 0.
Any ideas?
My Map file contains:
LAYER
NAME "US state boundaries"
TYPE LINE
STATUS ON
DATA "statesp020"
TEMPLATE "dummy1" ## added to make layer query work
PROJECTION
"proj=latlong"
END
CLASS
OUTLINECOLOR 230 230 230
SYMBOL 0
END
END
Thanks for you help.
Troy
