DHTML reference image with out position:absolute
Mike Davis
mike.and.kerry at GMAIL.COM
Fri May 13 19:44:48 EDT 2005
Has anyone figured out how to capture coordinates from a reference map
in a DHTML interface without using position:absolute?
I am designing an interface in which requires nesting the reference
map inside other divs and the absolue positioning is throwing
everything off.
If I change the positioning to float:center I can line everything up
all right, but then I loose the click-to-pan functionality.
Thanks
-Mike
