Python test failure on Mac
David Huttleston Jr
dhjr at HDDESIGN.COM
Sat May 14 13:16:16 EDT 2005
On Sat, May 14, 2005 at 11:12:41AM -0600, Sean Gillies wrote:
> On May 14, 2005, at 11:03 AM, David Huttleston Jr wrote:
> >On Fri, May 13, 2005 at 04:54:35PM -0600, Sean Gillies wrote:
> >>On May 13, 2005, at 4:11 PM, David Huttleston Jr wrote:
> >>>Hello All,
> >>>I'm in the process of porting Mapserver and some of it's supporting
> >>>libraries to Mac OS X. The results of which will be released as part
> >>>of the DarwinPort project for others to download and build.
> >>>I've bumped into a byte order error on the MapCloningTestCase. I
> >>>haven't seen anything on google or the archives so I thought I'd ask
> >>>the list before I get ugly with this. I know others have used
> >>>MapServer on a Mac, has anyone else seen this before?
> >>>% python runalltests.py -v
> >>>check attributes of a cloned class ... ok
> >>>testConstructorNoArg (classtest.ClassObjTestCase) ... ok
> >>>testConstructorWithArg (classtest.ClassObjTestCase) ... ok
> >>>MapCloningTestCase.testClonedLayers: the layers of a cloned map equal
> >>>the original ... ERROR 1: CPLVerifyConfiguration(): byte order set
> >>>wrong.
> >>Never seen that before, and haven't heard anything from other OS X
> >>(10.3) mapscript users. Looks like a GDAL error.
> >>MapCloningTestCase.testClonedLayers doesn't even render an image, so
> >>I'm not sure where it comes into play. Maybe there's an assert
> >>somewhere?
> >Yes, it looks assertion-like. Here is what I found in the gdal source
> >code, at line 405 of cpl_conv.cpp
> >void CPLVerifyConfiguration()
> >/* Verify data types.
> > CPLAssert( sizeof(GInt32) == 4 );
> > CPLAssert( sizeof(GInt16) == 2 );
> > CPLAssert( sizeof(GByte) == 1 );
> > if( sizeof(GInt32) != 4 )
> > CPLError( CE_Fatal, CPLE_AppDefined,
> > "sizeof(GInt32) == %d ... yow!\n",
> > sizeof(GInt32) );
> >/* Verify byte order
> > GInt32 nTest;
> > nTest = 1;
> >#ifdef CPL_LSB
> > if( ((GByte *) &nTest)[0] != 1 )
> >#endif
> >#ifdef CPL_MSB
> > if( ((GByte *) &nTest)[3] != 1 )
> >#endif
> > "CPLVerifyConfiguration(): byte order set wrong.\n"
> >>You forgot to tell us the most important information: which mapserver
> >>and GDAL versions are you building?
> >Oops. Here's the libraries related to gdal and mapserver:
> > mapserver 4.4.1
> > gdal 1.1.9_1
> > jpeg 6b_0
> > libgeotiff 1.2.1_0
> > libpng 1.2.8_1
> > proj 4.4.7_0
> > tiff 3.7.1_0
> > zlib 1.2.2_1
> >It seems odd that this hasn't been hit before. So, I'm suspicious now
> >of how gdal was built. :-/ Is there a good way to test gdal?
> Norman Vine has confirmed that this is a GDAL bug that was only very
> recently fixed. The fix might be present in the latest GDAL release.
> Check the change log to find out for sure. At any rate, you should
> really be using a newer GDAL. I'd also recommend MapServer from the
> CVS head of the 4.4 branch. There have been some important fixes since
> 4.4.1.
Excellent, I will try the newer code for both gdal and mapserver.
Thank you very much, Sean. For the info and the blinding speed of
your response. :-)
Dave
