PHP/Mapscript and gdal, segfault?
Frank Warmerdam
fwarmerdam at GMAIL.COM
Mon May 16 07:16:20 PDT 2005
On 5/15/05, Vortex <vortex25 at gmx.de> wrote:
> Hello!
> I'm using PHP/Mapscript for a while. It works perfectly
> until now although php is running as an apache dso.
> I know that this is discouraged, but a few people
> already mentioned that it works.
> Now i have discovered that all input formats using
> the gdal library (or at least geotiff) causes a segfault.
> Can anybody confirm this?
> It would be a pitty if i switch to php running as cgi
> although this problem could be fixed easy and maybe
> isn't related to the php dso at all.
Klaus,
I am not aware of any specific incompatibility between
GDAL and use of PHP MapScript as a dso. You might want
to try with non-GeoTIFF files that still go through GDAL and/or
try with the cgi version to help determine the boundary of the
problem. I *suspect* there is a conflicting libtiff in use which
can cause all sorts of pain.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
