3D LINE STRING / LINE STRING shapfiles
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon May 16 14:01:38 EDT 2005
Support was added in version 4.4 if I remember correctly.
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=869
It was already possible to use them through OGR before that.
Just use TYPE LINE in your MAP file.
Best regards,
Bart
On Mon, 16 May 2005 19:44:08 +0200, Carlos Timóteo <ctimoteo at GMAIL.COM>
wrote:
> i am working with a couple of ESRI shapefiles.
> the geometry type of all the files is 3D LINE STRING SHAPE and LINE
> STRING (tool ogrinfo)
> i search in the mailing list and i not found any question about this.
> mapserver can handle with this types ??
> i only see support for LINE,POINT,POLYGON etc
> in the case of 3D LINE STRING, maplab preview doesn't show anything,
> in the case of LINE STRING it shows the (road's) lines but query
> doesn't work at all.
> is this a mapserver support fail or a maplab error ??
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
