specifying path relative to SHAPEPATH
Abe Gillespie
abe.gillespie at GMAIL.COM
Tue May 17 13:01:47 EDT 2005
I'm not sure what the implications of directory privileges are ... but
could it be possible the webserver has access to
/var/www/html/wcs/test/Pressure and not /var/www/html/wcs/test ?
-Abe
On 5/17/05, Norman Barker <nbarker at rsinc.com> wrote:
> Hi,
> within my MAP object I have specified a
> SHAPEPATH '/var/www/html/wcs/'
> and then within my layer object I have
> DATA 'test/Pressure/dbIndex'
> however this fails, but works if I have
> SHAPEPATH '/var/www/html/wcs/test/Pressure' and DATA as
> 'dbIndex'
> Can I specify relative directories and shape filename to shapepath with the
> DATA tag?
> Many thanks,
> Norman Barker
