Performance ArcIMS vs MapServer
Moisan Yves
ymoisan at GROUPESM.COM
Fri May 20 08:18:27 EDT 2005
Hi Johan,
I may add that your set up definitely should have favored ArcIMS since the C#/.NET windows platform definitely is not the most user supported platform for MapServer.
To be on the devils'a advocate side a bit, I wonder if IronPython instead of C# would have made a difference. I know ArcGIS comes with a Python interpreter (an old 2.1 though) so I wonder how other ESRI products play with Python and how that could be leveraged in IronPython (or CPython, but then you're outside the .NET domain).
Thanx for sharing this experiment with us.
Yves Moisan
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Johan Hallgren
Envoyé : 20 mai 2005 02:42
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Performance ArcIMS vs MapServer
Hello
We have created a testapplication that can be used on ArcIMS and now
MapServer.
Both MapServer and ArcIMS are on the same server (Windows 2000 server)
with the same data (200 MB vectordata in shapefiles).
MapServer is wrapped in a c#/dotnet webservice. The API to the webservice
is ArcXML so both solutions have the same interface.
The testapplication used sex simultaneous clients requested 500 maps each
in total 3000 maps.
RESULTS:
Total time: 7.47 min (467 sec 0.1566 sec/map (image), 385 maps/min)
Max delay for a map: 2.93 sec
Min delay for a map: 0.14 sec
Average for a map (with six simultaneous clients): 0.96 sec
ArcIMS
Total time: 12.08 min (728 sec 0.2426 sec/map (image), 247 maps/min)
Max delay for a map: 3.94sec
Min delay for a map: 0.12 sec
Average for a map (with six simultaneous clients): 1,49 sec
My calculations gives that MapServer is about 30% faster when zooming than
ArcIMS
Cheers
Johan
