OGR connection for LINUX
Tyler Mitchell
tylermitchell at SHAW.CA
Mon May 23 09:57:14 EDT 2005
'MYSQL:database=abruzzo,tablename=zzz,user=arit,password=arit,host=localhost,port:3306'
> I get this message:
> Warning 1: 'tablename=zzz' in MYSQL datasource
> definition not recognised and ignored.
> Warning 1: 'port:3306' in MYSQL datasource definition
> ERROR 1: MySQL connect failed for:
Your port setting looks wrong. You have:
port:3306
it should be:
port=3306
The warning above tells you this is part of the problem. Hope that helps.
Tyler
