Cleaning the /tmp directory
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon May 23 13:43:20 EDT 2005
On Linux I use:
find /data/mdata/tmp -type f -mmin +20 -exec rm -f {} \;
from a root crontab entry.
If you have perl running on your windows server, here is a script that
will remove all the tmp files that are older the 20 min. This was
generated by find2perl and then modified. Use at your own risk.
-Steve W.
#! /usr/bin/perl -w
eval 'exec /usr/bin/perl -S $0 ${1+"$@"}'
if 0; #$running_under_some_shell
use strict;
use File::Find ();
#################################### config here #########
my $older = 20/1440; # 20 minutes / 1440 minutes/day
my $scan_dir = '/data/mdata/tmp';
# Set the variable $File::Find::dont_use_nlink if you're using AFS,
# since AFS cheats.
# for the convenience of &wanted calls, including -eval statements:
use vars qw/*name *dir *prune/;
*name = *File::Find::name;
*dir = *File::Find::dir;
*prune = *File::Find::prune;
sub wanted;
# Traverse desired filesystems
File::Find::find({wanted => \&wanted}, $scan_dir);
exit;
sub wanted {
my ($dev,$ino,$mode,$nlink,$uid,$gid);
(($dev,$ino,$mode,$nlink,$uid,$gid) = lstat($_)) &&
-f _ &&
(-M _ > $older) &&
unlink($_);
Lester Caine wrote:
> John Kim wrote:
>> > from : http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH72
>> > there is :
>> > Setup MapServer IMAGEDIR and cleanup script
>> Any tips on how you'd do this in Windows?
> I just run a scheduled task which is a batch file that deletes all the
> files. It runs a midnight, so anybody working at that time might see a
> problem.
> I really must get round to writing a program that just deletes anything
> over x hours old so that it is not so violent with files that have just
> been created ;)
> Lester Caine
> L.S.Caine Electronic Services
