Cleaning the /tmp directory
Ken Lord
kenlord at GMAIL.COM
Tue May 24 15:50:05 EDT 2005
Hi Ed,
I had thought the failures might be due to overloading our 'Boat Anchor'
brand webserver, but the failures happen whether its one or a dozen
snapshots being generated. Our websites do not handle much volume as they
are focused to a small group of specific private users.
That being said, we are switching over to a new webserver, with a separate
new computer as a PostGIS database server, and saying goodbye to the P3 era.
Hopefully the new hardware will help, at the very least its going to speed
up our websites a lot, if not I'll dive back into the URL's that generate
the snapshots.
Cheers,
Ken
On 5/24/05, Ed McNierney <ed at topozone.com> wrote:
> Ken -
> If you are trying to serve multiple simultaneous requests, with
> everything competing to write and then read files from the temp directory,
> the disk I/O to that drive can become a *serious* bottleneck. If heavy
> usage is not a concern, then this may be a non-issue.
> I have never seen failures due to MODE=MAP (rather than being caused by
> something else) and I've used it about a billion times (literally <g>). I
> would be leery of blaming failures on MODE=MAP without some diagnosis about
> the cause.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com <http://topozone.com/> / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
> Behalf Of *Ken Lord
> *Sent:* Tuesday, May 24, 2005 12:48 PM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] Cleaning the /tmp directory
> James,
> I use the method you mentioned, 'MODE=MAP', to generate snapshots for
> query results. It works great to highlight each individual item returned by
> a map query, placed next each item's attributes.
> However, Since mapserver 4 and later have come out, often the images fail
> despite the log statement of 'normal execution'.
> I have simplified the maps as much as possible, and I'm sure that its not
> a lingering syntax difference between 3.6 (where it worked great) and 4 or
> later. The failures are not consistant either. Why they don't either all
> work or all fail, or at least all the same features queried fail
> consistantly? I have no idea.
> So I'm leary about suggesting people use MODE=MAP for all their maps just
> to keep their temp folder's empty, especially when a simple .bat file can be
> used to empty them regularly.
> Cheers,
> Ken Lord
> Vancouver BC
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050524/316fd9b4/attachment.html
