mapserv.exe
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Wed May 25 03:34:19 EDT 2005
Try putting your IP address into the IMAGEURL.
eg if your IP address is 192.168.3.27:
IMAGEURL "http://192.168.3.27/mapserver/tmp/"
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Lluís Garcia i Mestres <lluisgm at gmail.com> 05/25/05 09:31am >>>
I have this in my web object.
IMAGEPATH "c:\archivos de programa\apache
group\apache2\htdocs\mapserver\tmp\"
IMAGEURL "http://[localhost]\mapserver\tmp\"
And in the template there are something suspicious:
Just the sclae function works
<TD align=middle>Escala 1:<SCRIPT language=JavaScript>document.write
(trunca([scale]));</SCRIPT>
and the others not...
<td align="left">
<img src="[scalebar]" alt="Scale bar" align="middle">
<img src="[legend]" alt="Scale bar" align="middle"><br>
2005/5/25, Bart van den Eijnden <BEN at syncera-itsolutions.nl>:
> What value do you have for IMAGEURL in your WEB object?
> Does it reference localhost?
> Best regards,
> Bart
> Syncera-ITSolutions
> Postbus 270
> 2600 AG DELFT
> tel.nr <http://tel.nr>.: 015-7512436
> >>> Lluís Garcia i Mestres <lluisgm at GMAIL.COM> 05/25/05 09:12am >>>
> Hi list,
> I'm working with mapserver 4.4.1 in mandrake 10.1 and it works fine. Now
> I'm triing to run it under windows. In my localhost the map is displayed,
> but if I try to display from another computer the template appears but the
> there are no map, legend, scaler and reference. It looks like the
> mapserver.exe doesn't work. My mapserv.exe is in the cgi-bin directory of
> apache and if it's ok for my localhost it should work also from others
> computers. Any suggestion?
> thanks
> Lluís Garcia i Mestres,
> lluisgm at hotmail.com
