Cleaning the /tmp directory
Patrick Weber
p.weber at UCL.AC.UK
Wed May 25 04:19:11 EDT 2005
Windows does have scheduled tasks which you can use to run any kind of
program, including batch scripts and so on.
Daniel Caldeweyher wrote:
> On Mon, 23 May 2005 09:29:59 -0700, John Kim <jkim at SCIENCES.SDSU.EDU> wrote:
>>>from : http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH72
>>>there is :
>>>Setup MapServer IMAGEDIR and cleanup script
>>Any tips on how you'd do this in Windows?
>>Thanks,
>>John
> I am using JavaMapscript with Tomcat and developed the following class to
> do the automated cleaning for me:
> to execute you simple write:
> new Thread(new Cleaner()).start()
> The temp file path and clean interval (in milliseconds; every 12 hours) is
> loaded from my configuration file. Modifying the code to not delete files
> that have been created in the last couple or minutes or so, should be
> fairly easy to implement:
> package au.edu.qpsf.ocis;
> import java.io.*;
> * @author Daniel Caldeweyher
> public class Cleaner implements Runnable {
> private String tempPath;
> private volatile boolean active;
> public void run() {
> this.active = true;
> while(active) {
> OpenCIS ocis = OpenCIS.getInstance();
> tempPath = ocis.getConfigParameter("imagepath");
> long waitInterval = Long.parseLong(ocis.getConfigParameter
> ("cleanup-interval"));
> File tempDir = new File(tempPath);
> if(tempDir.exists() && tempDir.isDirectory() && tempDir.canWrite
> System.out.println("Start cleanup: " +
> tempDir.getAbsolutePath());
> File[] files = tempDir.listFiles();
> int numFilesDeleted = 0;
> for(File f : files) {
> if(f.canWrite()) {
> f.delete();
> numFilesDeleted++;
> System.out.println("Deleted " + numFilesDeleted + " temp
> files, could not delete " + (files.length - numFilesDeleted) + " files.");
> try { Thread.sleep(waitInterval);
> } catch (InterruptedException ie) { active = false; }
> public void stopCleaner() {
> active = false;
> public String getTempPath() {
> return tempPath;
> public void setTempPath(String tempPath) {
> this.tempPath = tempPath;
> This solution will work on any operating system, including windows which is
> missing cron jobs.
> Daniel
________________________________________
Patrick Weber | p.weber at ucl.ac.uk
Research Associate
Centre for Advanced Spatial Analysis
http://www.casa.ucl.ac.uk/
University College London
