OGR Join and class {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri May 27 17:11:03 EDT 2005
Dear Emil,
Thanks for your suggestions.
Defining the CLASSITEM without table name prefix (either lowercase or
uppercase) results "Invalid Field name: mycol" :(
I think I've tried all combinations.
Bye
Zoltan
On Fri, 27 May 2005, Emil Zegers wrote:
> Hello Siki,
> Have you tried defining the CLASSITEM without the table name prefix and/or
> switching column name to lowercase:
> CLASSITEM "MYCOL"
> or
> CLASSITEM "mycol"
> or maybe
> CLASSITEM "ms.mycol"
> Regards,
> Emil
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
> Behalf Of Siki Zoltan
> Sent: donderdag 26 mei 2005 22:56
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] OGR Join and class {Scanned}
> Hi,
> I would like to define classes based on an OGR Joined (ODBC) column.
> I was not able to make the class definitions.
> My layer definition looks like:
> LAYER
> NAME test
> CONNECTIONTYPE OGR
> CONNECTION kafold.shp
> DATA "SELECT kafold.*, ms.* FROM kafold LEFT JOIN
> 'ODBC:admin/xxx at mydb'.ms ON kafold.hrsz=ms.hrsz"
> TYPE POLIGON
> STATUS DEFAULT
> CLASSITEM "ms.MYCOL"
> CLASS
> EXPRESSION /x/
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> END
> END
> If I remove CLASSITEM and EXPRESSION line the layer is drawn, so the DATA
> definition is good.
> I also tried to to remove CLASSITEM and give an expression like
> EXPRESSION ('[ms.MYCOL]' = 'x')
> I get an error massage in the apache error log
> libpng warning Incomplete compressed datastream in iCCP chunk
> Any idea?
> Thanks
> Zoltan
