Printing WMS layers in ArcMap 9.0
Bonnie Stewart
Bonnie.Stewart at DLI.WA.GOV.AU
Sun May 29 23:45:03 EDT 2005
Hi all,
Technically, I suspect this question would be more appropriate for an ArcGIS users forum, but from what I can find there's not a lot of help out there on ArcGIS issues, so I was hoping someone else from the Mapserver-users community might be using ArcMap, and might have encountered this issue before.
I've got a couple of mapfiles up and running which are include various vector and raster layers, and mostly I'm accessing them via ArcMap 9.0. However, I'm having trouble getting ArcMap to print my WMS images - print preview always comes up blank, and if you go ahead and print a page anyway, it's blank.
ArcMap's Help says that ArcMap converts maps to .emf (Windows Enhanced Metafile) for printing, and suggests manually doing an export to .emf and then opening up the .emf to see where the problem lies. Well, I've done this, and the .emf comes out entirely blank. To compare, I've tried exporting to .bmp, and that comes out fine.
Is there a problem with exporting WMS images to .emf?
Is it possible to get ArcMap to print from a different export format?
I have absolutely no GIS experience, so it's probably something very obvious, but all help would be much appreciated!
(Would be happy to provide the mapfiles etc, but as I can print fine in Internet Explorer, and ArcExplorer 4, I don't think it's an issue with the mapfiles..)
Cheers,
Bonnie
Bonnie Stewart
Research Officer
Satellite Remote Sensing Services
Department of Land Information
Email: Bonnie.Stewart at dli.wa.gov.au
Phone: 9387 0342
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this in error, please notify the author by Return email to the sender. Information in this message not relating to the official business of DLI shall be understood as neither given nor endorsed by it. While every care is taken, it is recommended that you scan any attachments for viruses. DLI liability is limited to re-supplying affected attachments.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050530/7155ec23/attachment.html
