OGR Join and class {Scanned}
Alberto Gomez
agomez at CCCMM.CESGA.ES
Mon May 30 04:37:58 EDT 2005
Try with this:
'ODBC:admin/xxx at mydb'.ms ms ON kafold.hrsz=ms.hrsz"
----- Original Message -----
To: "Alberto Gomez" <agomez at CCCMM.CESGA.ES>
Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, May 27, 2005 11:17 PM
Subject: Re: [UMN_MAPSERVER-USERS] OGR Join and class {Scanned}
> Hi Alberto,
> Thanks for your suggestion.
> Changing the table name results "Invalid Fiels name: kafold.MYCOL"
> Bye
> Zoltan
> On Fri, 27 May 2005, Alberto Gomez wrote:
> > Hi Siki,
> > Try to replace
> > > CLASSITEM "ms.MYCOL"
> > by CLASSITEM "kafold.MYCOL"
> > I hope this help,
> > Alberto
> > From: "Siki Zoltan" <siki at AGT.BME.HU>
> > To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> > Sent: Thursday, May 26, 2005 10:55 PM
> > Subject: [UMN_MAPSERVER-USERS] OGR Join and class {Scanned}
> > > Hi,
> > > I would like to define classes based on an OGR Joined (ODBC) column.
> > > I was not able to make the class definitions.
> > > My layer definition looks like:
> > > LAYER
> > > NAME test
> > > CONNECTIONTYPE OGR
> > > CONNECTION kafold.shp
> > > DATA "SELECT kafold.*, ms.* FROM kafold LEFT JOIN
> > > 'ODBC:admin/xxx at mydb'.ms ON kafold.hrsz=ms.hrsz"
> > > TYPE POLIGON
> > > STATUS DEFAULT
> > > CLASS
> > > EXPRESSION /x/
> > > COLOR 255 0 0
> > > OUTLINECOLOR 0 0 0
> > > END
> > > END
> > > If I remove CLASSITEM and EXPRESSION line the layer is drawn, so the
DATA
> > > definition is good.
> > > I also tried to to remove CLASSITEM and give an expression like
> > > EXPRESSION ('[ms.MYCOL]' = 'x')
> > > I get an error massage in the apache error log
> > > libpng warning Incomplete compressed datastream in iCCP chunk
> > > Any idea?
> > > Thanks
> > > Zoltan
