Printing WMS layers in ArcMap 9.0
Bonnie Stewart
Bonnie.Stewart at DLI.WA.GOV.AU
Mon May 30 04:12:48 EDT 2005
Cheers Mike.
I've actually just found the answer in one of ESRI's user forums:
http://forums.esri.com/Thread.asp?c=132&f=1341&t=157673&mc=2
Just in case that link moves:
Subject Re: print wms service
Author Graeme Browning
Date May 10, 2005
Message
Hi Bastian
I came across something similar trying to use Export Map to PDF on a WMS layer that exported fine to JPG and was given this advice:
"My guess is the JPG files export without problems because they at drawing at a resolution of 96 dpi. This is the default resolution for JPG exports. PDF exports, however, have a default resolution of 300 dpi. We've reproduced the draw failure here, it occurs in all formats when resolution is 300 dpi. The service layers are dropped in all export formats and during printing. This confirms that the failure is occuring at draw time.
We looked further into the issue, and identified a limitaion on the server's end as the cause of the draw failure. When we peeked at the server's response from the request sent during the 300 dpi export, it returned an exception message stating, "Image is wider than maximum allowed width of 2000". In order to draw the service layer at a resolution of 300 dpi, ArcMap had requested an image of width=3063 height=2619. The server raised the exception instead of returning the image.
While this layer draw failure is not caused by our export implementation, we probably need to do a better job of providing feedback when exceptions occur during output. When pixel size limit errors occur on draw to the screen, ArcMap displays an information dialog to inform the user of the exception. Output, however, does not provide any feedback mechanism. For now, the only workaround I can recommend is outputing your PDF file at a lower resolution, something close to 96 dpi. "
In my case turning the resolution down to 150dpi achieved the result I was looking for - perhaps you can try doing the same.
- Graeme
Graeme Browning
ESRI Australia
While this was talking about JPG files, the problem was similar with .emf files. I tried exporting to .emf at 200 dpi instead of the default 300, and the image came out OK. When you go to print, you can't specify the dpi numerically, but there's a "Output Image Quality" slider from Fast -> Normal -> Best. I changed it to 'Fast' (default is 'Best'), and it printed (and previewed - but you have to cancel out of the Print dialog in order to preview) fine.
Hopefully this info saves somebody else from the puzzled few days I just had :)
Cheers,
Bonnie
Bonnie Stewart
Research Officer
Satellite Remote Sensing Services
Department of Land Information
Email: Bonnie.Stewart at dli.wa.gov.au
Phone: 9387 0342
From: UMN MapServer Users List on behalf of Mike Davis
Sent: Mon 30/05/2005 3:23 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [Maybe SPAM] Re: [UMN_MAPSERVER-USERS] Printing WMS layers in ArcMap 9.0
Bonnie-
We use ArcMap extensively and it has become standard practice in our
GIS shop to export everything to .pdf before printing.
I am not sure about WMS bugs specifically, but the various other
problems we have encountered while trying to print maps from the
modern (8.x 9.x) Arc programs are often solved by using .pdf.
good luck
-Mike
On 5/29/05, Bonnie Stewart <Bonnie.Stewart at dli.wa.gov.au> wrote:
> Hi all,
> Technically, I suspect this question would be more appropriate for an ArcGIS
> users forum, but from what I can find there's not a lot of help out there on
> ArcGIS issues, so I was hoping someone else from the Mapserver-users
> community might be using ArcMap, and might have encountered this issue
> before.
> I've got a couple of mapfiles up and running which are include various
> vector and raster layers, and mostly I'm accessing them via ArcMap 9.0.
> However, I'm having trouble getting ArcMap to print my WMS images - print
> preview always comes up blank, and if you go ahead and print a page anyway,
> it's blank.
> ArcMap's Help says that ArcMap converts maps to .emf (Windows Enhanced
> Metafile) for printing, and suggests manually doing an export to .emf and
> then opening up the .emf to see where the problem lies. Well, I've done
> this, and the .emf comes out entirely blank. To compare, I've tried
> exporting to .bmp, and that comes out fine.
> Is there a problem with exporting WMS images to .emf?
> Is it possible to get ArcMap to print from a different export format?
> I have absolutely no GIS experience, so it's probably something very
> obvious, but all help would be much appreciated!
> (Would be happy to provide the mapfiles etc, but as I can print fine in
> Internet Explorer, and ArcExplorer 4, I don't think it's an issue with the
> mapfiles..)
> Cheers,
> Bonnie
> Bonnie Stewart
> Research Officer
> Phone: 9387 0342
> This e-mail and any files transmitted with it are intended only for the use
> of the addressee(s). It may contain information that is confidential and
> privileged. If you are not an intended recipient, any use, interference
> with, disclosure, distribution or copying of this material is unauthorised
> and prohibited. If you receive this in error, please notify the author by
> Return email to the sender. Information in this message not relating to the
> official business of DLI shall be understood as neither given nor endorsed
> by it. While every care is taken, it is recommended that you scan any
> attachments for viruses. DLI liability is limited to re-supplying affected
> attachments.
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this in error, please notify the author by Return email to the sender. Information in this message not relating to the official business of DLI shall be understood as neither given nor endorsed by it. While every care is taken, it is recommended that you scan any attachments for viruses. DLI liability is limited to re-supplying affected attachments.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050530/288b45d8/attachment.html
