Mapscript API: for object manipulation, not object creation?
Rick Innis
rick at INNIS.CA
Mon May 30 16:02:10 EDT 2005
> Great. The sooner, the better. We're aiming for a 4.6 release to
> coincide with next month's meeting.
> No, I forgot momentarily that SWIG-Java doesn't support optional
> method arguments as we have with Python. There is no zero argument
> constructor for Java. Calling the ordinary constructor with a NULL
> argument should be equivalent.
Doesn't appear to be. This is what I get in the logfile:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x400A3D89
Function=__libc_free+0x49
Library=/lib/tls/libc.so.6
Current Java thread:
at edu.umn.gis.mapscript.mapscriptJNI.mapObj_insertLayer
(Native Method)
at edu.umn.gis.mapscript.mapObj.insertLayer(mapObj.java:341)
Two possibly related items:
While the docs say the insert methods return the index at which the
object was inserted, the Java API doesn't seem to support this - it
supports a range of "insertFoo(foo, index)" methods.
Also, I notice that if I do a "make clean" in mapserver-4.4.2, I need
to do a "make interface" in mapserver-4.4.2/mapscript/java before I
can rebuild the Java API - which is then slightly different from the
one I get "out of the box". Mainly seems to be in the MS_ classes,
which define their statics as objects "out of the box" but ints after
a rebuild.
--Rick.
