MapServer 4.6.0-beta3 released
Joshua Buysse
buysse at SOCSCI.UMN.EDU
Tue May 31 12:25:32 EDT 2005
> The list of fixes since beta2 is included below.
> - Bug 1354: Added a regex wrapper, allowing MapServer to build with PHP
> compiled with its builtin regex
Whatever changed here, my problems building mapserver with PHP
Mapscript on Redhat Enterprise 4 are now resolved. Before this change,
whenever I built with PHP support, all variants would core dump loading
a mapfile (CGI, Python, PHP, etc.).
I have been working to build mapserver as a clean RPM with Redhat's PHP
and Postgres packages, so that only minimal changes from the base OS
need to be made. I made a slight modification to the PHP packages to
install the regex object files in /usr/include/php/regex (with the
include files), and built a few support packages.
Almost all of the packages that I've used are based on the
mappinghacks.com packages, and I'm releasing my modified versions here:
http://www.socsci.umn.edu/~buysse/mapserver/
If anyone's interested in them, I'm going to be maintaining versions of
these packages for RHEL 4.
Josh Buysse, System Administrator
CLA-OIT, Division of Research Computing Services
University of Minnesota
"Democracy should not be for export only."
-- Jesse Jackson
http://www.suntimes.com/output/jesse/cst-edt-jesse30.html
