MapServer 4.6.0-beta3 released
Ken Lord
kenlord at GMAIL.COM
Tue May 31 16:20:21 EDT 2005
Hi Daniel,
I'm using the build of 4.6beta3 for windows that was made available for
download from maptools.org <http://maptools.org> today.
If TRANSPARENT is within the outputformat, mapserver fails and returns the
following error message:
"GD/JPEG OUTPUTFORMAT jpeg has TRANSPARENT set ON, but this is not
supported. It has been disabled."
Leaving TRANSPARENT out of the outputformat block prevents the error
message, and the map appears to be generating properly including
transparancy. Previously I had to have TRANSPARENT ON in my outputformat
block to enable transparancy.
If this was the intended effect, then just the 4.6 documentation needs to
be updated for the syntax change. I brought this up because the change was
not listed in the revision history in history.txt, and the mapserver log and
our flash interface don't show this error message, leaving me to try it out
in an HTML template when our flash site failed.
Thanks again,
Ken
On 5/31/05, Daniel Morissette <dmorissette at dmsolutions.ca> wrote:
> Ken Lord wrote:
> > I don't know if this is a bug or a feature, but the move from 4.6beta2
> > to 4.6beta3 has disabled the use of the parameter "TRANSPARENT ON/OFF"
> > within OUTPUTFORMAT.
> Well, setting TRANSPARENT ON/OFF (or TRUE/FALSE) in an OUTPUTFORMAT
> block in the mapfile works for me with 4.6beta3, and the resulting image
> has the right transparency (I used GIF for my tests).
> What happens or doesn't happen exactly for you? Is it that you get a
> mapfile parsing error, or simply that transparency appears to not be
> working but you get no error message? Are you sure it's not something
> else that changes in your test environment (or a broken build)? Perhaps
> you could file a bug if you are able to include a simple testcase to
> reproduce.
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050531/39655974/attachment.html
