Install problem
Kumar
kumar at NEWFIELDS.COM
Tue Oct 4 23:34:26 EDT 2005
I am not sure where you set the favicon but you can try just putting a
favicon in the directory. I had the same problem, even thou I didn't use
favicon in the code it was looking for it (It maybe an apache setting
somewhere). Anyways just get a favicon and try. Hopefully it will fix your
problem.
- kumar
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Stephen Crawford
Sent: Tuesday, October 04, 2005 9:32 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Install problem
All,
I'm a MapServer newbie, though I know a bit about WMS and WFS, having used
GeoServer and ArcIMS in some projects. On my desktop machine running XP
I've installed Apache 2.0; downloaded MapServer 4.4.1 Windows binaries, and
added "C:\MapServer" to Path and added the PATH_LIB variable to point to the
appropriate place. When I try to go to localhost/cgi-bin/mapserv.exe I get
"Internal Server Error", and the server error log gives me this:
"Premature end of script headers: mapserv.exe" and "File does not exist:
C:/Program Files/Apache Group/Apache2/htdocs/favicon.ico"
Apache itself seems to be working (get the welcome page for localhost).
Any thoughts?
Thanks,
Steve
Stephen Crawford
Center for Environmental Informatics
GeoVISTA Center
The Pennsylvania State University
814.865.9905
src176 at psu.edu
