TILEINDEX EXPRESSION = Seg Fault
Frank Warmerdam
warmerdam at POBOX.COM
Thu Oct 6 11:50:01 EDT 2005
On 10/6/05, Shannon Scott <sscott at gwi.net> wrote:
> Hello,
> I am reposting this message because no one responded. Has anyone else
> experienced this issue?
> Recently we reorganized some data for map performance, and started using the
> TILEINDEX Layer parameter. I have noticed an issue with the EXPRESSION
> parameter when used with TILEINDEX.
> Here is the output from gdb ( debug enabled ):
> 0x08065822 in msEvalExpression (expression=0x99f5b08, itemindex=0,
> items=0x0, numitems=161833360)
Shannon,
The "items" pointer is not supposed to be NULL. That is why things
are crashing. I don't know why it is NULL though. I really think you
may need to submit a bug report with all the information (map file,
data, invocation, full traceback etc) to reproduce the problem so the
developers can track it down and fix it properly.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
