gdal_merge.py usage
Frank Warmerdam
warmerdam at POBOX.COM
Thu Oct 6 12:05:02 EDT 2005
On 10/6/05, Travis Kirstine GIS Tech <tkirstine at jdbarnes.com> wrote:
> I've been trying without success to use gdal_merge.py. I've download the
> latest version of FW Tools and tried to use gdal_merge with the following
> command
> >"C:\Program Files\FWTools0.9.8\pymod\gdal_merge.py" tiff_merge_test
> orth176170475152002fbs.tif orth176170475202002fbs.tif
> orth176170475252002fbs.tif
> With this I received the message to "Select Program to open gdal_merge.py"
> I then checked any threads that could help
> http://list.maptools.org/pipermail/gdal_dev/2003-August/000985.html
> and tried to set my environmental variables to
> >set OPENEV_HOME="C:\Program Files\FWTools0.9.8"
> >set path=%OPENEV_HOME%\bin;%OPENEV_HOME%\python\Lib;\%PATH%
> >set PYTHONHOME=%OPENEV_HOME%\python
> >set
> PYTHONPATH=%OPENEV_HOME%\pymod;%PYTHONHOME%\include\Numeric;%PYTHONHOME%\Lib
> This didn't seem to do anything and I still received the message Select
> Program message, I then browsed to
> C:\Program Files\FWTools0.9.8\python\python.exe
> and received the error message "application has failed, python23.dll not
> found"
Travis,
This is really a MapServer question and would be better asked on the
FWTools or gdal-dev lists.
I would strongly encourage you to execute the gdal_merge.py script
from the "FWTools Shell", or to call the same environment initialization
bat file it uses (the setfw.bat file).
Also, in the BIN directory of FWTools there is a gdal_merge.bat. If you
use that, it will take care of calling the right python executable.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
