mapscript - queryByAttributes: Aborted
Sean Gillies
sgillies at FRII.COM
Sun Oct 9 11:55:00 EDT 2005
On Oct 9, 2005, at 3:44 AM, Jachym Cepicky wrote:
> Ok, I get this error no more. Anyway, it does not work, how I would
> expect:
> my $layerObj = $mapObj->getLayerByName("landuse");
> $layerObj->queryByAttributes($mapObj, 'number', '10850',
> $mapscript::MS_SINGLE);
> my $resultCacheObj = $layerObj->getResults();
> # but there is no $resultCacheObj defined
> print $resultCacheObj,"\n";
> # Use of uninitialized value in print at ./mapserv2.pl line 70.
> How to perform the attribute query with mapscript?
> Thanks
> Jachym
Do you have a template set for your layer? See section 2.2 in
http://zcologia.com/mapserver/querying-howto. This is one of
mapscript's worst quirks.
The second argument of queryByAttributes becomes a temporary layer
filteritem, and the third argument becomes a temporary layer filter.
See
http://ms.gis.umn.edu/docs/howto/msexpressions/howto_view
If you don't actually have a 'number' item in the layer, then the query
will fail and getResults() will return NULL.
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
