Need some help on WMS server.
Paul Turner
pturner at CCALMR.OGI.EDU
Mon Oct 10 12:36:02 EDT 2005
I'm bringing up a WMS server and I'm having problems serving different
images from the same map file. It looks like only the last image of the
3 is being served.
The server is at
http://www.ccalmr.ogi.edu/cgi-bin/mapserv?map=/usr/local/apache/mapserver/wms.map
There are 3 images served, one per layer, and each is different (I've
verified this) but it seems that in every WMS client I use, the same
image shows up no matter which layer I select (the last image).
Any suggestions appreciated.
Thx,
--Paul
Paul J Turner
OHSU-OGI-CCALMR
mapserver CGI is configured thusly:
/usr/local/apache/cgi-bin) mapserv -v
MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Here is the map file:
MAP
NAME "CORIE Dev Forecast"
DEBUG ON
# SIZE 550 450
# IMAGETYPE GIF
UNITS DD
EXTENT -125.300000 45.300000 -122.844754 47.299633
WEB
LOG "/tmp/mapserver.log"
IMAGEPATH "/usr/local/apache/htdocs/ms/tmp"
IMAGEURL "/ms/tmp/"
METADATA
"wms_title" "CORIE WMS Service"
"wms_onlineresource"
"http://www.ccalmr.ogi.edu/cgi-bin/mapserv?map=/usr/local/apache/mapserver/wms.map&"
##required
"wms_srs" "epsg:4326"
"wms_format" "image/gif"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "devforecast1"
STATUS DEFAULT
DUMP TRUE
METADATA
"wms_title" "DevForecast 1" ##required
"gml_include_items" "all"
END
TYPE RASTER
DATA "/usr/local/apache/mapserver/llcolsal_plume_surface_000090000.gif"
PROJECTION
"init=epsg:4326" ##recommended
END
END
LAYER
NAME "devforecast2"
STATUS DEFAULT
DUMP TRUE
METADATA
"wms_title" "DevForecast 2" ##required
END
TYPE RASTER
DATA "/usr/local/apache/mapserver/llcolsal_plume_surface_000093600.gif"
PROJECTION
END
END
LAYER
NAME "devforecast3"
STATUS DEFAULT
DUMP TRUE
METADATA
"wms_title" "DevForecast 3" ##required
END
TYPE RASTER
DATA "/usr/local/apache/mapserver/llcolsal_plume_surface_000097200.gif"
PROJECTION
END
END
END
The images can be seen at (warning, 2048x2048):
http://www.ccalmr.ogi.edu/ms/llcolsal_plume_surface_000090000.gif
http://www.ccalmr.ogi.edu/ms/llcolsal_plume_surface_000093600.gif
http://www.ccalmr.ogi.edu/ms/llcolsal_plume_surface_000097200.gif
