attributes, WFS?
Stefanie Weykam
sweykam at TELELINE.ES
Wed Oct 12 06:21:47 EDT 2005
Leopold,
Unless the user actually queries a wms or wfs layer, you may use MapScript
and QueryByPoint ().
$pt is your pountObj , the user click-point converted to map coordinates
if (@$currentLayer->queryByPoint($pt, MS_SINGLE ,0)==MS_SUCCESS)
$result = $currentLayer->getResult(0);
$currentLayer->open();
# get the names of the fields - only needed once per layer
$items = $currentLayer->getitems(); # array with column names
if (!empty($items))
foreach($items as $j)
echo $j; # column names
## get the shapeobj - each result has a shape-, tile- and classindex
$data_shp=$currentLayer->getshape($result->tileindex,$result->shapeindex);
## get the values from the shapeobj
$data_val = $data_shp->values; # array values
$currentLayer->close();
best regards,
Stefanie
