Querying the extents of a layer (shapefile)
Fawcett, David
David.Fawcett at STATE.MN.US
Fri Oct 14 09:17:53 EDT 2005
I would suggest that you give us a little more info. Lay out what you
are trying to do, most likely, someone will have an idea of how to get
you there.
David.
-----Original Message-----
Sent: Thursday, October 13, 2005 4:40 PM
To: 'Fawcett, David'; MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] Querying the extents of a layer
(shapefile)
Thanks,
I have done that before but I can only do that manually. I need a
method either inside of Mapserver, in VBScript in an ASPX page, in
Javascript in the Template page, or PHP to do this and then pass it to
Mapserver to render the next map.
Chip Taylor
Prepared Response, Inc.
> From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
> Sent: Thursday, October 13, 2005 1:12 PM
> To: work at XWB.COM; MAPSERVER-USERS at lists.umn.edu
> (shapefile)
> You can run ogrinfo on it and get the extents
> http://ogr.maptools.org/ogr_utilities.html
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On Behalf Of Chip Taylor
> Sent: Thursday, October 13, 2005 2:34 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Querying the extents of a layer
> (shapefile)
> If I have a shapefile as a layer can I query the extents of that
> shapefile from MapServer or MapScript?
> Thanks for all the help you give to us poor newbies.
> Chip Taylor
