PHP/MapScript: WRAP failed
Ralph Anthes
anthes at IVE-MBH.DE
Fri Oct 14 09:42:25 EDT 2005
Hi Dirk,
thank you for response. That matches the problem. What is the 32 for? Is
this the Ascii-Code?
I have the same problem with a "-". Is there a number available too?
Best regards
Ralph
Dirk Tilger schrieb:
>On Fri, Oct 14, 2005 at 02:03:31PM +0200, Ralph Anthes wrote:
>>$label->set("wrap"," ");
>>I want to wrap at whitespaces of a description. When I use the wrap in
>>the map file it works fine.
>I've never used label objects. I had a quick look at mapscript and I
>would give...
>| $label->set("wrap",32);
>... a try.
>Dirk.
Dipl.-Ing. Ralph Anthes
Ingenieurgesellschaft für Verkehrs- und Eisenbahnwesen mbH
Vahrenwalder Platz 3, 30165 Hannover
Telefon: 0511/984228-18
Fax: 0511/984228-29
http://www.ive-mbh.de
