Linking problems
Prashanth Ram
pram123 at GMAIL.COM
Sat Oct 15 18:12:52 EDT 2005
Philip:
Create a link to that file (from /usr/lib or /usr/local/), and everything
should work. In order to find the file you can either do whereis
libgd.so.2or locate
libgd.so.2.
-Prashanth
HTMLX.com
Mapserver Hosting, Mapscript Hosting, PHP Hosting
PostgreSQL w/PostGIS extension enabled Hosting
On 10/15/05, Philip Mark Donaghy <philip.donaghy at gmail.com> wrote:
> Thanks Pram,
> My last problem was resolved by rerunning ./configure
> Now that mapserv is built I tried it out and the gd library is not getting
> linked.
> opensource at lns-bzn-31-82-252-227-123:~/soft/bin/mapserver-4.6.1> ldd
> mapserv
> linux-gate.so.1 => (0xffffe000)
> libgd.so.2 => not found
> libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x4002b000)
> libpng.so.3 => /usr/lib/libpng.so.3 (0x40093000)
> libc.so.6 => /lib/tls/libc.so.6 (0x400c1000)
> libm.so.6 => /lib/tls/libm.so.6 (0x401d7000)
> libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x401fa000)
> libz.so.1 => /lib/libz.so.1 (0x402b7000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x402c9000)
> The LD_LIBRARY_PATH environment variable solves this...
> opensource at lns-bzn-31-82-252-227-123:~/soft/bin/mapserver-4.6.1> export
> LD_LIBRARY_PATH=/usr/local/lib
> mapserv
> libgd.so.2 => /usr/local/lib/libgd.so.2 (0x40018000)
> libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x40065000)
> libpng.so.3 => /usr/local/lib/libpng.so.3 (0x400cd000)
> libc.so.6 => /lib/tls/libc.so.6 (0x40110000)
> libm.so.6 => /lib/tls/libm.so.6 (0x40226000)
> libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40249000)
> libpng12.so.0 => /usr/local/lib/libpng12.so.0 (0x40306000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40338000)
> Apache is having the same problem but the environment variable does not
> resolve this. error_log...
> [Sat Oct 15 23:59:22 2005] [error] [client ::1]
> /home/opensource/soft/bin/httpd-2.0.54/cgi-bin/mapserv: error while
> loading shared libraries: libgd.so.2: cannot open shared object file: No
> such file or directory
> Thanks for any hints,
> Philip
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051015/277a4dc7/attachment.html
