Upgrade Problems - Additional Info
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Oct 17 10:46:54 EDT 2005
All,
We've been using clients with these types of precision coordinates for quite some time now with no issues whatsoever.
I did some testing further to this, and I have no problems giving a similar request (coord precision wise), to another WMS:
http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?version=1.1.1&service=WMS&request=GetMap&layers=naps&styles=&bbox=-141.00000000,35.187499998,-51.999999997,90.812500001&format=image/png&srs=EPSG:4326&width=500&height=300
...since this one's mine, I know that the underlying data in this case is a shapefile.
Tim's example underlying data is coming as a result of an .ovf definition connection.
Infact, I have received another email this morning with the exact same issue, and same setup/environment.
Is or has something happened to the way the .ovf or underlying OGR process handles precision of coordinates when doing spatial filters?
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Richard
> Orth - osmoGIS Incorporated
> Sent: Saturday, 15 October, 2005 00:07
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Upgrade Problems - Additional Info
> Do you have to use 13 or 14 decimal places (16 numerals)? I
> got it down
> to 8 decimals before it stopped working. This would suggest
> the use of a
> float variable instead of a double (sorry I had to use a JAVA
> example).
> This does work (8 decimal):
> http://cabin.cciw.ca/cabin_ows.asp?version=1.1.1&service=WMS&r
equest=GetMap&layers=CABINPoints&styles=&bbox=-> 141.00000000,35.18749999,-51.99999999,90.81250000&format=image
> This does not work (9 decimals):
equest=GetMap&layers=CABINPoints&styles=&bbox=-> 141.000000002,35.187499998,-51.999999997,90.812500001&format=i
> Even this does not work (11 numerals each):
equest=GetMap&layers=CABINPoints&styles=&bbox=-> 141.00000000,35.187499998,-51.999999997,90.812500001&format=im
> Hope this helps you
> Richard C Orth
> Pascoe,Tim [Burlington] wrote:
> >Wierd. Even this works:
> request=Ge
> >And even this works:
> request=Ge
> >tMap&layers=CABINPoints&styles=&bbox=-150,40,-50,80&format=im
> age/png&sr
> >But this don't:
> request=Ge
> >tMap&layers=CABINPoints&styles=&bbox=-141.0000000021858,35.18
> 7499998633
> >86,-51.99999999781418,90.81250000136613&format=image/png&srs=
> EPSG:4326&
> >...the only difference between the last two requests is the
> >coordinates. You may want to pass this to the list as a
> follow up to
> >your thread.
> >..Tom
> > From: Pascoe,Tim [Burlington]
> > Sent: Friday, 14 October, 2005 14:43
> > To: Kralidis,Tom [Burlington]
> > Subject: Huh?
> > Tom,
> > Why is it this works, and not the other request?
request=Ge
>tMap&layers=CABINPoints&sld=http%3A%2F%2Fcabin.cciw.ca%2Fcabin%2Fmaps%2
>Fstudy_sld_script.php%3FSLDFilterValue%3D108%26SLDParameter%3Dstudyid
> Timothy Pascoe
> Environment Canada / Environnement Canada
> Canada Centre for Inland Waters / Centre Canadien des Eaux Intérieures
> 867 Lakeshore Road / 867, chemin Lakeshore
> Burlington, Ontario / Burlington (Ontario)
> L7R 4A6
> Tel/Tél: (905) 336-6239
> Fax/Téléc: (905) 336-4699
> E-mail/C. élec: tim.pascoe at ec.gc.ca
> Government of Canada/Gouvernement du Canada
> This e-mail represents the opinions and views solely held by its
>author and in no manner may be considered as representing those of
>his/her employer.
