queryByPoint accuracy/confusion
Tim Norris
tibben at OCF.BERKELEY.EDU
Mon Oct 17 15:36:26 EDT 2005
Perhaps this is not the place for these questions and I should be posting
this observation to the PROJ4 list . . . in any case input would be
appreciated. Sorry in advance if this observation is out of place.
So now that I have reminded myself that measuring distance on maps is a
difficult matter, I have a further question regarding the distance measuring
tools in mapServer (in particular with the use of the Mercator projection).
After a little research, the problem regarding measuring distances when
using the standard Mercator projection would be a variable issue based on
lattitude. This is fairly obvious if we think about the way the Mercator
projection works, and perhaps my best solution is to choose a better
projection for my area of interest (California - perhaps a version of UTM
would give me better measurments - in fact I am reasonably certain it would).
But the big questions for me is - since there are errors within the distance
measuring tools, do the same errors exist in the scalebar tools??
After measuring a few scalebars and comparing them to paper maps of
California it would seem that the answer is yes. All of the scalebars drawn
through mapServer are short (using the Standard Mercator between lattitudes
33 and 38).
Even though the answer is that there is an error using distances with the
Standard Mercator with my system, I am, to say the least, unclear as to
where this problem lies . . . PROJ4 problem?? . . . a compile problem?? . .
. a GDAL problem?? some other issue???
I am sure that I can fudge a workaround for this, but at the same time . . .
any guidance for an eleant solution would be greatly appreciated . . .
for reference the following were my build steps:
for Proj4
[root at maps proj-4.4.9]# ./configure
[root at maps proj-4.4.9]# make
[root at maps proj-4.4.9]# make install
[root at maps proj-4.4.9]# cp ~/epsg /usr/local/share/proj/epsg
for GDAL
[root at maps gdal-1.2.6]# make clean
[root at maps gdal-1.2.6]# ./configure --with-ogr --without-python --with-xerces
[root at maps gdal-1.2.6]# make install
[root at maps gdal-1.2.6]# /sbin/ldconfig
for mapserver
[root at tuna mapserver4.4.2]# rm -f config.cache
[root at tuna mapserver4.4.2]# ./configure --without-tiff --with-threads
--with-proj --with-gdal=/usr/local/bin/gdal-config --with-ogr
--with-php=../php-5.0.4 --with-gd=/usr/local --with-freetype=/usr/bin
--with-pdf --with-wmsclient --with-wfs --with-wfsclient
[root at tuna mapserver4.4.2]# make clean
[root at tuna mapserver4.4.2]# cp mapserv /var/www/cgi-bin/mapserv_40
[root at tuna mapserver4.4.2]# cp mapscript/php3/php_mapscript.so
/usr/local/php/extensions/php_mapscript_40.so
as noted in the earlier post, I am using mapServer with PHP mapscript on a
Fedora/apache system and all my data is MapInfo (through OGR) - other than
this problem, mapServer has performed much better than commercial software
that I have used in the past.
thanks
tim
Tim Norris
ps: this has also been posted to the PROJ4 listserv
