classitem variable substitution
    Charlton Purvis
    cplist at EARTHLINK.NET
    Tue Oct 18 13:44:38 PDT 2005
Hi, folks:
I poked around on the archives and couldn't find a post related to this.
I'm sure it's there, and I apologize for not laying my finger on it.
But is a variable substitution on a CLASSITEM not allowed?  Var. sub. works
fine elsewhere, just not here.
I am trying to hit a .shp and have the CLASSITEM be dependant on one of its
columns or whatever they're called in the .shp world.
Error . . .
msDBFGetItemIndex(): DBASE file error. Item '%TARGETTIME%' not found.
.map excerpt . . .
  LAYER
    NAME elevation
    PROJECTION
      "proj=latlong"
    END
    DATA
"/home/cpurvis/scoop/adcirc/SADCec95-UNC_WNAHNOPR-NCP_%STARTTIME%_20051017T1
300_20051022T1200_elev_ZGIS-ele"
    TYPE POLYGON
    STATUS DEFAULT
    CLASSITEM "%TARGETTIME%"
    CLASS
      STYLE END
      OUTLINECOLOR 0 0 0
    END
  END
I have tried playing around w/ single and double quotes, but no luck.
I'm used to PostGIS, and I could jolly well do this on the DATA line as an
alias, but staying w/i the shapefile world for this project is probably the
way to go.
Thanks!
Charlton
More information about the MapServer-users
