using oraclespatial data in map
Oliver Wesp
wesp at GDV.COM
Wed Oct 19 03:37:10 EDT 2005
Try changing your data statement to
DATA "SHAPE FROM ESRI.COUNTRY_TSQA USING SRID xxxxx"
Change xxxxx to whatever SRID your spatial table has. You can lookup the
SRID in MDSYS.ALL_SDO_GEOM_METADATA
Oliver
John Cartwright schrieb:
> Hello All,
> I'm trying to use oracle spatial table (geographic WGS84 coords) as a
> layer in a map and seem to be having trouble w/ the projection. The
> layer is defined as:
> LAYER
> NAME admin2
> CONNECTIONTYPE oraclespatial
> CONNECTION "dbuser/dbpass at oraclehost"
> DATA "SHAPE FROM ESRI.COUNTRY_TSQA"
> STATUS off
> TYPE polygon
> CLASS
> OUTLINECOLOR 0 0 255
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> However, mapserver seems to be generating an SQL query w/ a NULL SRID:
> ORA-13208: internal error while evaluating [window SRID does not
> match layer SRID] operator
> ORA-06512: at "MDSYS.SDO_INDEX_METHOD_10I", line 281
> ORA-06512: at line 1
> . Query statement: SELECT rownum, SHAPE FROM ESRI.COUNTRY_TSQA WHERE
> SDO_FILTER( SHAPE, MDSYS.SDO_GEOMETRY(2003, NULL,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-179.75,-89.875,179.75,89.875)
> ),'querytype=window') = 'TRUE' . Check your data
> statement.
> Can anyone help me with the proper mapfile syntax?
> Thanks!
> -- john
Dipl.-Geogr. Oliver Wesp
Gesellschaft fuer geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
