ESRI Layer Files
Paul Ramsey
pramsey at REFRACTIONS.NET
Wed Oct 19 11:34:16 EDT 2005
Chip,
I have often thought the same thing. Hexdumpping the files, it is
really hard to see the structure at all. The best explanation I have
heard is that the lyr is a serialized COM object, which means it will
be next to impossible to reverse engineer. It makes one miss the
old .avl files and ArcView 3.
Paul
On Oct 19, 2005, at 7:19 AM, Chip Taylor wrote:
> I have a fairly complex ESRI Layer file (.lyr) that I would like to
> use in a Mapserver application. Is there a way for Mapserver to
> use the .lyr file, or failing that, convert the .lyr file to a
> shapefile? I have ESRI ArcMap and ArcCatalog but haven’t found
> anything there either.
> Chip Taylor
> Prepared Response, Inc.
> 1127 Broadway Plaza, Suite 204
> Tacoma, WA 98402
> O 253.272.1730
> M 253.948.2525
> STATEMENT OF CONFIDENTIALITY
> The information contained in this electronic message and any
> attachments to this message are intended for the exclusive use of
> the addressee(s) and may contain confidential or privileged
> information. If you are not the intended recipient, please notify
> Prepared Response, Inc. immediately at (206) 223-5544 and destroy
> all copies of this message and any attachments.
