problem in running java-mapscript
orkun
temiz at DEPREM.GOV.TR
Thu Oct 20 03:52:08 EDT 2005
listuser HH wrote:
> orkun wrote:
>> Fernando Simon wrote:
>>> Hi Orkun,
>>> The Java will read the lib from classpath.
>>> So you need to put your lib in path that java can read, or in the
>>> lib system path (if it's appear in classpath).
>>> Regards
>>> Fernando Simon
>>> Mapserver and Oracle Spatial developer
>>> G10 - Laboratorio de Computacao Aplicada - Brazil
>>> http://www.univali.br/g10 - UNIVALI/CTTMAR
>>> orkun wrote:
>>>> hello
>>>> I am new to java
>>>> I am trying to run a javamapscript.
>>>> But I am receiving an error message :
>>>> import edu.umn.gis.mapscript.*;
>>>> public class jeo2 {
>>>> public static void main(String[] args) {
>>>> try
>>>> System.loadLibrary("libmapscript.so");
>>>> catch(UnsatisfiedLinkError ule)
>>>> System.err.println(ule);
>>>> System.exit(-1);
>>>> java.lang.UnsatisfiedLinkError: no libmapscript.so in
>>>> java.library.path
>>>> what should library path be ?
>>>> regards
>>>> Ahmet Temiz
>>>> ______________________________________
>>>> XamimeLT - installed on mailserver for domain @deprem.gov.tr
>>>> Queries to: postmaster at deprem.gov.tr
>>>> The views and opinions expressed in this e-mail message are the
>>>> sender's own
>>>> and do not necessarily represent the views and the opinions of
>>>> Earthquake Research Dept.
>>>> of General Directorate of Disaster Affairs.
>>>> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
>>>> olarak T.C.
>>>> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
>>>> nitelikte degildir.
>> thank you I checked CLASSPATH again.
>> mapscript resides in /usr/local/ and classpath
>> as in Eclipse :
>> <classpath>
>> <classpathentry kind="src" path=""/>
>> <classpathentry exported="true" kind="con"
>> path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
>> <classpathentry exported="true" kind="lib"
>> path="/home/orkun/work/postgresql.jar"/>
>> path="/usr/local/mapscript.jar" />
>> <classpathentry kind="output" path=""/>
>> </classpath>
>> for instance postgresql.jar works well but mapscript does not.
>> there might be another problem ?
>> regards
>> sender's own
>> olarak T.C.
>> nitelikte degildir.
> Hi,
> did you check your system if it knows the library "libmapscript.so"?
> You can try that with "ldconfig -vNX".
> Regards,
> Norbert
thank you
I created mapscript.jar and libmapscript.so.
I think they don't have any problems because test map worked well and
produced map.png.
But I don't know where to put these files.
Where should mapscript.jar and libmapscript.so reside ?
What should classpath be ?
regards
Ahmet Temiz
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
