java-mapscipt examples
Bas Vanmeulebrouk
bvanmeul at EBE.UCT.AC.ZA
Fri Oct 21 05:01:10 EDT 2005
Hello Ahmet, list
I am not very experienced in Java MapScript either, but I may have some
code which may be usefull for you. In my servlet, I have got a
MapServerMap object to encapsulate MapScript. I create this object like
this:
public MapServerMap(String aMapFileName) throws Exception {
super();
try {
File f = new File(aMapFileName);
if (f.exists()) {
Map = new mapObj(aMapFileName);
} else {
throw new Exception("Map file not found: " + aMapFileName);
} catch (UnknownError e) {
throw new Exception(ErrorMessages.errCreatingMapServerMap);
} catch (Exception e) {
throw new Exception(e.getMessage());
And I use it like this for instance:
public void Zoom(int aZoomFactor) {
float x = Map.getWidth() / 2;
float y = Map.getHeight() / 2;
pointObj point = new pointObj(x, y, 0.0, 0.0);
Map.zoomPoint(aZoomFactor, point, Map.getWidth(),
Map.getHeight(), Map
.getExtent(), null);
After I have done all the panning, zooming, filtering and turning layers
on and off I draw the map like this:
public String Draw() throws MapServerException {
try {
* Draw the map and return the URL under which it was stored
imageObj image = Map.draw();
String fn = "map_" + getUniqueID() + "."
+ Map.getOutputformat().getExtension();
image.save(StringUtils.CheckAndAppend(image.getImagepath(),
"\\") + fn, Map);
return StringUtils.CheckAndAppend(image.getImageurl(), "/") +
fn;
throw new MapServerException("Error drawing map.");
Hope this helps.
Cheers,
Bas.
orkun wrote:
> hello
> As a new for java-mapscipt, I need to see related examples.
> I will appreciate, if you provide any examples.
> regards
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the
> sender's own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
