antialiasing line features..
Steve Lime
steve.lime at DNR.STATE.MN.US
Mon Oct 24 14:05:21 EDT 2005
Just to wrap things up. Antialising has not been removed. In testing independent of MapServer
I have been unable to get GD to produce antialised lines with 8-bit output formats. You might
try setting IMAGETYPE PNG24 and see if that helps.
Steve
>>> Jeff de La Beaujardiere <jeff2005 at SVS.GSFC.NASA.GOV> 10/21/05 9:08 AM >>>
Ivan Price wrote:
> you are having more luck than me.. I am using the following and getting
> a non-antialiased line still. Perhaps antialiasing has been removed from
> the cartoline's capabilities in later versions ?
This is what works for me:
SYMBOL
NAME "cartoline"
TYPE cartoline
LINECAP butt
LINEJOIN miter
LINEJOINMAXSIZE 1
END
LAYER
NAME "countries"
TYPE LINE
STATUS on
PROJECTION
"init=epsg:4326"
END
DATA "........../wms/data/borders/cntry02.shp"
METADATA
"wms_title" "National Boundaries"
"wms_layer_group" "/Reference"
END
CLASS
NAME "BORDERS"
STYLE
COLOR 200 200 200
SYMBOL "cartoline"
ANTIALIAS TRUE
SIZE 1
END
END
END
Try comparing speeds with TRUE and FALSE in the above
with a dataset that has many line segments.
