Handling apostrophes in field names and class expressions
Steve Lime
steve.lime at DNR.STATE.MN.US
Mon Oct 24 14:34:18 EDT 2005
Debbie: Your example exression should work just fine. MapServer doesn't support escaping
of characters within string espressions. That shouldn't be a problem unless you have strings
with both single and double qoutes in them. You just need to use the quoting method opposite
of the characters. I have data here full of the name O'Brien and I just tested with a layer defiinition
like:
LAYER
NAME 'test'
TYPE POLYGON
STATUS ON
DATA 'lakes'
CLASSITEM 'name'
CLASS
EXPRESSION "O'Brien"
COLOR 255 0 0
END
CLASS
EXPRESSION /O'Brien/
COLOR 0 0 255
END
END
and I get what I expected. Features with the exact match are red and those with O'Brien as a substring
are blue. This is 4.7 on Linux but there have be few if any changes in that area of the code since 4.6.1
was released.
Steve
>>> "Pagurek,Debbie [NCR]" <Debbie.Pagurek at EC.GC.CA> 10/21/05 4:10 PM >>>
Hi all,
I'm experiencing some difficulties with a mapfile that I'm using that
has apostrophes in fieldnames and also apostrophes in class expressions.
Funny - I thought my problems would all happen because of the French
characters, but that doesn't appear to be the problem.
For instance - can someone confirm that a CLASS Expression "Cours d'eau"
will work?
Mapserver 4.6.1, Windows.
Can anyone comment on what Mapserver does with encoding?
D. Pagurek
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Frank Warmerdam
Sent: Friday, October 21, 2005 4:16 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] RFC 5 - Horizon clipping during
reprojection
On 10/21/05, Bruce Raup <brauplists at gmail.com> wrote:
> Hi Frank,
> RFC-5 was just today called to my attention. I think it's great that
> this is being (has been) addressed. Two closely related issues (I
> think) are these:
> A. How are polygon vertices joined? 1) By straight lines in the
> projection, or 2) as great-circle arcs? Can this be specified in the
> mapfile? If not, it would be great to have a LAYER-level parameter,
> something like JOINVERTICES=greatcircle or JOINVERTICES=straightline.
> The GMT program "psxy" offers such a choice (the -A option).
Bruce,
Currently a straight line in the output projection is created between
the point at which the polygon boundary went "over the edge", and where
it came back. This does result in anomolies as we can see a bit in the
sample images I provided.
The reason something smarter (like great circles or some other way to
track the horizon) wasn't done was limited time. The client decided
they didn't want to fund that degree of fidelity unless they find the
current approach unsatisfactory.
> B. When making a selection in the mapserver viewport (via jbox, for
> example), only the corner coordinates of that box get converted back
> to the coordinate system of the data, which means that what is
> selected can be very different from what you see. I wrote about this
> before. See http://spot.colorado.edu/~braup/MapServer/ for an example
> of polar weirdness. Has this issue made it to the bug list? I can do
> that if you guide me on how.
I am aware of this problem, but there has been no effort (other than a
bit of thinking) to resolve it. I'm not sure if there is a bug report
on this issue or not. You can find info at the following url on how to
submit bugs.
http://ms.gis.umn.edu/development/bugs/
The case of reprojecting bounding boxes is handled specially via the
msProjectRect() (in mapproject.c) and this function already has lots of
logic about sampling along edges, and through the rect if some points
fail to reproject. But it does not have any logic to deal with special
polar issues. If we could force it to use the internal sampling for
such cases that would help though not completely resolve the issue.
I have included the code in case you would like to skim it and consider
possible fixes.
There is a wiki area for discussion of "world mapping problems" where I
liked to accumulate such issues, but with the wiki locked down now there
isn't an easy place to catalog such things.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
ack. This does result in anomolies as we can see a bit in the sample
images I provided.
submit bugs.
Best regards,
/* msProjectGrowRect()
#ifdef USE_PROJ
static void msProjectGrowRect(projectionObj *in, projectionObj *out,
rectObj *prj_rect, int *rect_initialized,
pointObj *prj_point, int *failure )
if( msProjectPoint(in, out, prj_point) == MS_SUCCESS )
if( *rect_initialized )
prj_rect->miny = MS_MIN(prj_rect->miny, prj_point->y);
prj_rect->maxy = MS_MAX(prj_rect->maxy, prj_point->y);
prj_rect->minx = MS_MIN(prj_rect->minx, prj_point->x);
prj_rect->maxx = MS_MAX(prj_rect->maxx, prj_point->x);
else
prj_rect->minx = prj_rect->maxx = prj_point->x;
prj_rect->miny = prj_rect->maxy = prj_point->y;
*rect_initialized = MS_TRUE;
else
(*failure)++;
#endif /* def USE_PROJ */
/* msProjectRect()
#define NUMBER_OF_SAMPLE_POINTS 100
int msProjectRect(projectionObj *in, projectionObj *out, rectObj *rect)
{ #ifdef USE_PROJ
pointObj prj_point;
rectObj prj_rect;
int rect_initialized = MS_FALSE, failure=0;
double dx, dy;
double x, y;
dx = (rect->maxx - rect->minx)/NUMBER_OF_SAMPLE_POINTS;
dy = (rect->maxy - rect->miny)/NUMBER_OF_SAMPLE_POINTS;
/* first ensure the top left corner is processed, even if the rect
turns out to be degenerate. */
prj_point.x = rect->minx;
prj_point.y = rect->miny;
#ifdef USE_POINT_Z_M
prj_point.z = 0.0;
prj_point.m = 0.0;
#endif /* USE_POINT_Z_M */
msProjectGrowRect(in,out,&prj_rect,&rect_initialized,&prj_point,
&failure);
/* sample along top and bottom */
if(dx > 0) {
for(x=rect->minx; x<=rect->maxx; x+=dx) {
prj_point.x = x;
&failure);
prj_point.x = x;
prj_point.y = rect->maxy;
&failure);
/* sample along left and right */
if(dy > 0) {
for(y=rect->miny; y<=rect->maxy; y+=dy) {
prj_point.y = y;
&failure);
prj_point.x = rect->maxx;
prj_point.y = y;
&failure);
** If there have been any failures around the edges, then we had
better
** try and fill in the interior to get a close bounds.
if( failure > 0 )
failure = 0;
for(x=rect->minx + dx; x<=rect->maxx; x+=dx) {
for(y=rect->miny + dy; y<=rect->maxy; y+=dy) {
prj_point.x = x;
prj_point.y = y;
&failure);
if( !rect_initialized )
if( out == NULL || out->proj == NULL
|| pj_is_latlong(in->proj) )
prj_rect.minx = -180;
prj_rect.maxx = 180;
prj_rect.miny = -90;
prj_rect.maxy = 90;
else
prj_rect.minx = -22000000;
prj_rect.maxx = 22000000;
prj_rect.miny = -11000000;
prj_rect.maxy = 11000000;
msDebug( "msProjectRect(): all points failed to reproject,
trying to fall back to using world bounds ... hope this helps.\n" );
else
msDebug( "msProjectRect(): some points failed to reproject,
doing internal sampling.\n" );
rect->minx = prj_rect.minx;
rect->miny = prj_rect.miny;
rect->maxx = prj_rect.maxx;
rect->maxy = prj_rect.maxy;
return MS_FAILURE;
else
return(MS_SUCCESS);
#else
msSetError(MS_PROJERR, "Projection support is not available.",
"msProjectRect()");
return(MS_FAILURE);
#endif
