AW: [UMN_MAPSERVER-USERS] Error drawing tiff image
Frank Broniewski
Frank.Broniewski at MNHA.ETAT.LU
Tue Oct 25 06:15:40 EDT 2005
Hello Frank,
Updating to version 4.6 solved indeed my problem. But thanks alot for
your answer.
Greetings Frank
Frank Broniewski
Musée National d'Histoire et d'Art
Section Préhistoire / Projet EPC
Tél: +352 260 281-21
241, Rue de Luxembourg
L-8077 Bertrange
-----Ursprüngliche Nachricht-----
Von: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] Im Auftrag von
Frank Warmerdam
Gesendet: Montag, 24. Oktober 2005 19:07
An: Frank Broniewski
Cc: MAPSERVER-USERS at lists.umn.edu
Betreff: Re: [UMN_MAPSERVER-USERS] Error drawing tiff image
On 10/24/05, Frank Broniewski <Frank.Broniewski at mnha.etat.lu> wrote:
> Hello List
> I have a problem with drawing a tif image. First the error message:
> Error in msRASTERLayerOpen(): Attempt to open a RASTER layer,
> but this is only supported after a raster query.
> phpinfo() gives the following information about mapserver
> MapServer Version:
> MapServer version 4.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> DEBUG=MSDEBUG
> PHP MapScript Version:
> ($Revision: 1.224 $ $Date: 2005/01/28 15:28:26 $)
> So what is going wrong there?
Frank,
A few folks have run into this in the past, but I don't recall the
details. I think it was fixed for the 4.6 release. I see that you are
running MapServer 4.5 which was the "development" version of mapserver
between 4.4 and 4.6. I think if you upgrade to 4.6 (or better yet our
current development 4.7!) the problem should go away.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
