Static compilation of Mapserver?
Daniele Margotti
margottid at COMUNE.LUGO.RA.IT
Tue Oct 25 09:37:05 EDT 2005
Hi list,
I want to use Mapserver on a remote Linux webserver, where I can upoload
CGIs.
Unfortunately, I have no shell access to this webserver, so I cannot
compile Mapserver directly on the machine.
But I have a Linux PC where I can compile/install all needed libraries
(Zlib, GD, Gdal, Libtiff, Proj, and so on) and, after that, compile CGI
Mapserver and PHP Mapscript.
Can I compile it including in the executable all those libraries? Would
then the Mapserver executable (or the Mapscript module) run even if
different libraries are installed on the webserver?
How can I do? (i.e.: which parameters should I add to "./configure" or
"make", or in the "Makefile"?)
Thank you,
Daniele
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051025/4adb9c37/attachment.html
