WFS layer display problem
Matthew Edmondson
matt0177 at GMAIL.COM
Wed Oct 26 18:47:44 EDT 2005
I have a layer (pulling from a shapefile) set up on my server set up to
share as a wfs layer. The layer displays properly, when tapped via a
getfeature request, the data comes back parsed properly with no errors, when
using a chameleon experssionbuilder widget, I can see each of the headers
for my columns of data. However, when I try to tap that wfs layer to display
it in a mapserver, I instantly get a red x in the upper left corner and my
map won't load. Even tyring to tap it in the same mapfile (as a wfs
connection to the url) gives me errors.
here is the layer attempting to tap the working layer (note, this is on a
intranet):
LAYER
NAME wfs_sightings_test
TYPE POINT
STATUS off
CONNECTIONTYPE WFS
CONNECTION "
http://10.59.36.53:8080/cgi-bin/mapserv?map=/var/www/html/fgs/apps/chameleon-2.0/test/map/test.map&typename=sightings2004_point
METADATA
"wfs_typename" "sightings2004_point"
"wfs_version" "1.0.0"
"wfs_request_method" "GET"
"wfs_connectiontimeout" "60"
"wms_srs" "epsg:4326"
END
END # Layer
I've read every piece of documentation I've found, and searched every
mailing list archive, and I've yet to see any reason why this should be
happening. Any help would be greatly appreciated.
Thanks,
Matt
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051026/9d07f944/attachment.html
