mapserver postgis connection
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Oct 27 14:23:23 EDT 2005
Frances Collier wrote:
> Hello,
> I’ve been trying to find out what exactly Mapserver gets back from
> Postgis when querying the tables. I haven’t found this to be documented
> anywhere. Does Postgis return a shape file, layer, or simply data rows?
> The reason I’m asking is that I noticed a huge time difference between
> connecting to Postgis and simply calling the shape files – with the
> Postgis being significantly slower
> I’d appreciate any knowledge, advice, and/or direction.
Frances,
PostGIS IS slower than shapefiles because:
1) You have to make a network of local connection to the database which
include some kind of authentication.
2) You have to do a query to fetch some data
3) The data needs to be transformed from its native PostGIS format into
whatever mapserver uses internally
4) all the data has to packaged up into packets to transfer from the
server to the client (mapserver)
5) probably other stuff too
So why would anyone want to use it?
Well you can do lots of cool GIS like things with it. You data might be
stored there for other purposes, like it is bing dynamically updated by
other process. You need to do thematic mapping, etc, etc
Should you put all or any of your data in PostGIS?
Depends on your need. If all you data is static data and you are only
display maps of it then probably not. Use shapefiles as they are most
efficient. You can take a hybrid approach of having some static layer in
shapefiles and some other layers in postGIS.
If you are doing queries the only look at a small percentage of the data
then postGIS queries can be optimized maybe to speed things up. If you
are just recalling all you data when zoomed out maybe you need another
layer where the data in simplified for that.
-Steve W.
http://imaptools.com
